I am currently working on an application that requires me to add custom fields to application.yml
As a simple example, suppose I wanted to alter the default shinyproxy config file to include a category
field for each spec entry, like this:
- id: 01_hello
category: cat1
access-groups: [scientists, mathematicians]
- id: 06_tabsets
category: cat2
access-groups: scientists
I have edited the ProxySpec.java
model in the containerproxy dependency by adding
private String category;
public String getCategory() {
return category;
public void setCategory(String category) {
this.category = category;
public void copy(ProxySpec target) {
target.setCategory(category);
and rebuilt the shinyproxy.jar
file with the edited dependency. If I change getCategory()
so that it returns one of the original data fields, i.e., id
, then I can return that value so I know the issue is not with my build process. For some reason, it appears that the private data field is never being set. I have read through this documentation https://docs.spring.io/spring-boot/docs/current/reference/html/boot-features-external-config.html and scoured the containerproxy repo, but can’t find any indication of what I’m missing here. If you can point me in the right direction it would be much appreciated.
Currently using shinyproxy-2.0.5 and containerproxy-0.6.0.
Here’s the full edited ProxySpec.java
* ContainerProxy
* Copyright (C) 2016-2018 Open Analytics
* This program is free software: you can redistribute it and/or modify
* it under the terms of the Apache License as published by
* The Apache Software Foundation, either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* Apache License for more details.
* You should have received a copy of the Apache License
* along with this program. If not, see <http://www.apache.org/licenses/>
package eu.openanalytics.containerproxy.model.spec;
import java.util.ArrayList;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
public class ProxySpec {
private String id;
private String displayName;
private String description;
private String logoURL;
private ProxyAccessControl accessControl;
private List<ContainerSpec> containerSpecs;
private List<RuntimeSettingSpec> runtimeSettingSpecs;
private Map<String, String> settings = new HashMap<>();
public ProxySpec() {
public String getId() {
return id;
public void setId(String id) {
this.id = id;
return category;
public String getDisplayName() {
return displayName;
public void setDisplayName(String displayName) {
this.displayName = displayName;
public String getDescription() {
return description;
public void setDescription(String description) {
this.description = description;
public String getLogoURL() {
return logoURL;
public void setLogoURL(String logoURL) {
this.logoURL = logoURL;
public ProxyAccessControl getAccessControl() {
return accessControl;
public void setAccessControl(ProxyAccessControl accessControl) {
this.accessControl = accessControl;
public List<ContainerSpec> getContainerSpecs() {
return containerSpecs;
public void setContainerSpecs(List<ContainerSpec> containerSpecs) {
this.containerSpecs = containerSpecs;
public List<RuntimeSettingSpec> getRuntimeSettingSpecs() {
return runtimeSettingSpecs;
public void setRuntimeSettingSpecs(List<RuntimeSettingSpec> runtimeSettingSpecs) {
this.runtimeSettingSpecs = runtimeSettingSpecs;
public Map<String, String> getSettings() {
return settings;
public void setSettings(Map<String, String> settings) {
this.settings = settings;
target.setId(id);
target.setDisplayName(displayName);
target.setDescription(description);
target.setLogoURL(logoURL);
if (accessControl != null) {
if (target.getAccessControl() == null) target.setAccessControl(new ProxyAccessControl());
accessControl.copy(target.getAccessControl());
if (containerSpecs != null) {
if (target.getContainerSpecs() == null) target.setContainerSpecs(new ArrayList<>());
for (ContainerSpec spec: containerSpecs) {
ContainerSpec copy = new ContainerSpec();
spec.copy(copy);
target.getContainerSpecs().add(copy);
if (runtimeSettingSpecs != null) {
if (target.getRuntimeSettingSpecs() == null) target.setRuntimeSettingSpecs(new ArrayList<>());
for (RuntimeSettingSpec spec: runtimeSettingSpecs) {
RuntimeSettingSpec copy = new RuntimeSettingSpec();
spec.copy(copy);
target.getRuntimeSettingSpecs().add(copy);
if (settings != null) {
if (target.getSettings() == null) target.setSettings(new HashMap<>());
target.getSettings().putAll(settings);
