Is there a way to configure the network for the docker container?, i.e. equivalent to:
docker run --net=host
Thanks,
Adiel
Thanks,
Adiel
Hi @Adiel_Loinger,
Many thanks for your interest in ShinyProxy. We currently only have a docker-dns
field which is the equivalent of docker run --dns
. Do you mean docker run --network
? I did not find any reference to a --net
option in the docs here. We could definitely add this option.
Hi @Adiel_Loinger,
ShinyProxy now (version 0.8.6) supports the equivalent of docker run --network
in a new (optional) field docker-network
that can be specified per Shiny app. See https://shinyproxy.io/downloads/
Can you let us know whether it works as intended for you?
Thanks @tverbeke! I appreciate your help.
Where should this new field be specified? under the docker section? Under apps?
Thanks,
Adiel
Hi @Adiel_Loinger,
Since for every application one can (potentially) launch a container from a different image, docker-network
is configured a the level of the individual application. See https://shinyproxy.io/configuration/#apps
Thanks @tverbeke.
I tried it out, but I get a “Container did not respond in time” error message.
Adiel
