When I am trying to start application in shinyproxy I get the following error
Caused by: java.util.concurrent.ExecutionException: javax.ws.rs.ProcessingException: org.apache.http.conn.HttpHostConnectException: Connect to localhost:2375 [localhost/127.0.0.1] failed: Connection refused (Connection refused)
- OS – RHEL
Docker.service file
[Unit]
Description=Docker Application Container Engine
Documentation=http://docs.docker.com
After=network.target
Wants=docker-storage-setup.service
Requires=rhel-push-plugin.socket registries.service
Requires=docker-cleanup.timer
[Service]
Type=notify
NotifyAccess=all
EnvironmentFile=-/run/containers/registries.conf
EnvironmentFile=-/etc/sysconfig/docker
EnvironmentFile=-/etc/sysconfig/docker-storage
EnvironmentFile=-/etc/sysconfig/docker-network
Environment=GOTRACEBACK=crash
Environment=DOCKER_HTTP_HOST_COMPAT=1
Environment=PATH=/usr/libexec/docker:/usr/bin:/usr/sbin
ExecStart=/usr/bin/dockerd-current \
/usr/bin/dockerd -H fd:// -D -H tcp://127.0.0.1:2375 \
–add-runtime docker-runc=/usr/libexec/docker/docker-runc-current \
–default-runtime=docker-runc \
–authorization-plugin=rhel-push-plugin \
–exec-opt native.cgroupdriver=systemd \
–userland-proxy-path=/usr/libexec/docker/docker-proxy-current \
$OPTIONS \
$DOCKER_STORAGE_OPTIONS \
$DOCKER_NETWORK_OPTIONS \
$ADD_REGISTRY \
$BLOCK_REGISTRY \
$INSECURE_REGISTRY\
$REGISTRIES
ExecReload=/bin/kill -s HUP $MAINPID
LimitNOFILE=1048576
LimitNPROC=1048576
LimitCORE=infinity
TimeoutStartSec=0
Restart=on-abnormal
MountFlags=slave
KillMode=process
[Install]
WantedBy=multi-user.target
