Hi, how are you? I hope you are doing well
I have a question. When you open the same app on the same browser on two different tabs, shinyproxy opens the same container or two different ones? How can I configure it to open two different containers.
Thank you!
This is currently not possible with ShinyProxy. The next version (ShinyProxy 2.6.0) will allow you to run multiple instances of an app. The instance is identified by the URL. Therefore if you open the same URL multiple times, the same instance will show up. Only when changing the name
of the instance in the URL another instance is opened.
