Failed to start container with shinyproxy-template
I am testing shinyproxy and I ran into problems when I wanted to deploy my own apps. I then build the openanalytics/shinyproxy-template container with the Euler-app and tried to add it to the basic application.yml. However, the example apps run fine but for the Euler app I get an error “Failed to start container”. I tested the image on its own and it worked fine. I would appreciate any help.
The application.yml looks like this:
  title: GC Test Proxy
  logo-url: http://www.openanalytics.eu/sites/www.openanalytics.eu/themes/oa/logo.png
  heartbeat-timeout: 60000
  admin-groups: boss
  # Example: 'simple' authentication configuration
    - name: jack
      password: password
      groups: boss
    - name: jeff
      password: password
      groups: normal
  # Docker configuration
    cert-path: /home/none
    url: http://localhost:2375
    port-range-start: 20000
    - id: testapp1
      display-name: Euler
      description: Euler App
      container-cmd: CMD ["R", "-e", "shiny::runApp('/root/euler')"]
      container-image: openanalytics/shinyproxy-template
      access-groups: [boss]
    - id: 01_hello
      access-groups: [boss, normal]
    - id: 06_tabsets
      access-groups: boss
The error I get is this:
Error
Status code: 500
Message: Failed to start container
Stack Trace:
eu.openanalytics.containerproxy.ContainerProxyException: Failed to start container
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.startProxy(AbstractContainerBackend.java:113)
at eu.openanalytics.containerproxy.service.ProxyService.startProxy(ProxyService.java:213)
at eu.openanalytics.shinyproxy.controllers.AppController.getOrStart(AppController.java:109)
at eu.openanalytics.shinyproxy.controllers.AppController.startApp(AppController.java:68)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:209)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:136)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:870)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:776)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:991)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:925)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:978)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:881)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:855)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:64)
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:94)
at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:159)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:336)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: com.spotify.docker.client.exceptions.DockerRequestException: Request error: POST http://localhost:2375/containers/c6baed8dbdcde23f1ce44e7d96e2c99a95f4b9d19cae9f7ae2b150de7a1c8626/start: 500, body: {"message":"OCI runtime create failed: container_linux.go:346: starting container process caused \"exec: \\\"CMD [\\\\\\\"R\\\\\\\"\\\": executable file not found in $PATH\": unknown"}
at com.spotify.docker.client.DefaultDockerClient.propagate(DefaultDockerClient.java:2838)
at com.spotify.docker.client.DefaultDockerClient.request(DefaultDockerClient.java:2732)
at com.spotify.docker.client.DefaultDockerClient.containerAction(DefaultDockerClient.java:781)
at com.spotify.docker.client.DefaultDockerClient.containerAction(DefaultDockerClient.java:766)
at com.spotify.docker.client.DefaultDockerClient.startContainer(DefaultDockerClient.java:761)
at eu.openanalytics.containerproxy.backend.docker.DockerEngineBackend.startContainer(DockerEngineBackend.java:91)
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.doStartProxy(AbstractContainerBackend.java:129)
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.startProxy(AbstractContainerBackend.java:110)
... 95 more
Caused by: javax.ws.rs.InternalServerErrorException: HTTP 500 Internal Server Error
at org.glassfish.jersey.client.JerseyInvocation.convertToException(JerseyInvocation.java:1098)
at org.glassfish.jersey.client.JerseyInvocation.translate(JerseyInvocation.java:883)
at org.glassfish.jersey.client.JerseyInvocation.access$500(JerseyInvocation.java:99)
at org.glassfish.jersey.client.JerseyInvocation$2.completed(JerseyInvocation.java:840)
at org.glassfish.jersey.client.ClientRuntime.processResponse(ClientRuntime.java:227)
at org.glassfish.jersey.client.ClientRuntime.access$200(ClientRuntime.java:85)
at org.glassfish.jersey.client.ClientRuntime$2.lambda$response$0(ClientRuntime.java:178)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:272)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:268)
at org.glassfish.jersey.internal.Errors.process(Errors.java:316)
at org.glassfish.jersey.internal.Errors.process(Errors.java:298)
at org.glassfish.jersey.internal.Errors.process(Errors.java:268)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:312)
at org.glassfish.jersey.client.ClientRuntime$2.response(ClientRuntime.java:178)
at org.glassfish.jersey.apache.connector.ApacheConnector$1.run(ApacheConnector.java:491)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at jersey.repackaged.com.google.common.util.concurrent.MoreExecutors$DirectExecutorService.execute(MoreExecutors.java:299)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
at jersey.repackaged.com.google.common.util.concurrent.AbstractListeningExecutorService.submit(AbstractListeningExecutorService.java:50)
at jersey.repackaged.com.google.common.util.concurrent.AbstractListeningExecutorService.submit(AbstractListeningExecutorService.java:37)
at org.glassfish.jersey.apache.connector.ApacheConnector.apply(ApacheConnector.java:487)
at org.glassfish.jersey.client.ClientRuntime.lambda$null$3(ClientRuntime.java:187)
at org.glassfish.jersey.client.ClientRuntime.lambda$createRunnableForAsyncProcessing$4(ClientRuntime.java:163)
... 3 more
Here is the relevant error part:
You have a typo in your container-cmd - “CMD” does not belong there, should be
      container-cmd: ["R", "-e", "shiny::runApp('/root/euler')"]
