Thanks for doing the work to integrate with an OIDC provider.
I am trying to get ShinyProxy (2.0) to work with Auth0. I’ve set up the app in Auth0 with domain:
I’ve added the correct Auth Endpoint, Token Endpoint, JWKS URL as well as client id and secret
The app is running here: http://144.202.13.207:8080/
From what I’m seeing, the callback URL is not a valid page:
http://144.202.13.207:8080/login/oauth2/code/shinyproxy
Not an expert so I am not sure if that’s what’s causing the issue. Any help would be greatly appreciated!
Alek
