Dear Shinyproxy team,
I use Shinyproxy with Keycloak authentification. The Website is called touchpointplanner.com and you can use the user testaccount and password “password” to try to login and see the error. There seems to be some kind of redirection. I searched here and found out that it might be a certificate issue, so these are the steps I did to import everything in the Keycloak Keystore and Java Truststore:
sudo openssl pkcs12 -export -in touchpointplanner.com.crt -inkey touchpointplanner.com.key -out touchpointplanner.com.p12 -name touchpointplanner.com -CAfile touchpointplanner.com.crt -caname root
sudo keytool -importkeystore -deststorepass keycloak17 -destkeypass keycloak17 -destkeystore /opt/keycloak-3.3.0.CR2/standalone/configuration/kctrust.jks -srckeystore touchpointplanner.com.p12 -srcstoretype PKCS12 -srcstorepass PASSWORD -alias touchpointplanner.com
sudo keytool -importkeystore -deststorepass PASSWORD -destkeypass PASSWORD -destkeystore /usr/lib/jvm/java-8-oracle/jre/lib/security/cacerts -srckeystore touchpointplanner.com.p12 -srcstoretype PKCS12 -srcstorepass PASSWORD -alias touchpointplanner.com
Following erros are logged:
Content match Service shinyproxy-log
Date: Wed, 03 Apr 2019 13:50:52
Action: alert
Host: spm1tp1.serviceplan.de
Description: content match:
2019-04-03 13:49:29.256 ERROR 93629 --- [XNIO-2 task-9] o.k.adapters.OAuthRequestAuthenticator : failed to turn code into token
2019-04-03 13:49:29.373 ERROR 93629 --- [XNIO-2 task-11] o.k.adapters.OAuthRequestAuthenticator : failed to turn code into token
2019-04-03 13:49:29.479 ERROR 93629 --- [XNIO-2 task-13] o.k.adapters.OAuthRequestAuthenticator : failed to turn code into token
Your faithful employee,
Monit
Action: alert
javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty Caused by: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty Caused by: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty ...
Monit
Can you help me with this problem?
