I created a docker image successfully, and when I do
docker run -p 3838:3838 celsiuspro/ems R -e 'shiny::runApp("/opt/ems")'
the shiny app works as expected.
This is my application.yml
shiny:
apps:
- name: ems
display-name: EMS
docker-cmd: ["R", "-e shiny::runApp('/opt/ems')"]
docker-image: celsiuspro/ems
groups: scientists
When I run shinyproxy, however, I get this:
2017-10-31 17:42:47.713 WARN 43420 — [ main] ationConfigEmbeddedWebApplicationContext : Exception encountered during context initialization - cancelling refresh attempt: org.springframework.context.ApplicationContextException: Unable to start embedded container; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘shinyProxyApplication’: Unsatisfied dependency expressed through field ‘dockerService’; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘dockerService’: Unsatisfied dependency expressed through field ‘dockerClient’; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘getDockerClient’ defined in class path resource [eu/openanalytics/services/DockerService.class]: Bean instantiation via factory method failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [com.spotify.docker.client.DockerClient]: Circular reference involving containing bean ‘dockerService’ - consider declaring the factory method as static for independence from its containing instance. Factory method ‘getDockerClient’ threw exception; nested exception is java.lang.NullPointerException
Plus a whole bunch of spring goodness, ending with
Caused by: java.lang.NullPointerException: null
at sun.nio.fs.UnixPath.normalizeAndCheck(UnixPath.java:77) ~[na:1.8.0_144]
at sun.nio.fs.UnixPath.(UnixPath.java:71) ~[na:1.8.0_144]
at sun.nio.fs.UnixFileSystem.getPath(UnixFileSystem.java:281) ~[na:1.8.0_144]
at java.nio.file.Paths.get(Paths.java:84) ~[na:1.8.0_144]
at eu.openanalytics.services.DockerService.getDockerClient(DockerService.java:175) ~[classes!/:1.0.1]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_144]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_144]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_144]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_144]
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:162)
What am I missing?
