I have some difficulties to connect my shiny app to a local and remote db with RPostreSQL.
Both databases are not runnning inside a container.
Summary of steps undertaken:
1. I first build the docker container with the dockerfile:
FROM rocker/r-devel
sudo \
build-essential \
pandoc \
pandoc-citeproc \
curl \
libxml2-dev \
libcairo2-dev \
libxt-dev \
libssl-dev \
libssh2-1-dev \
libpcre3 \
libpcre3-dev \
libpq-dev
libmpfr-dev
RUN R -e "install.packages(c( \
'tidyverse', \
'stats', \
'methods', \
'shinyWidgets', \
'shiny', \
'shinyBS', \
'shinydashboard', \
'shinyjs', \
'readr', \
'readxl', \
'cellranger', \
'attempt', \
'dplyr', \
'magrittr', \
'pool', \
'RPostgreSQL', \
'stringr', \
'purrr', \
'glue', \
'lubridate' \
), repos='https://cloud.r-project.org/')"
RUN mkdir /root/mypackage
COPY mypackage_0.1.0_R_x86_64-pc-linux-gnu.tar.gz /root/mypackage
RUN R -e "install.packages('/root/mypackage/mypackage_0.1.0_R_x86_64-pc-linux-gnu.tar.gz', repos = NULL, type='source')"
CMD ["R", "-e", "mypackage::run_shiny_app()"]
2. Then the application.yml:
shiny:
title: Shiny app with postgres connection
heartbeat-timeout: 60000
container-wait-time: 60000
hide-navbar: true
authentication: none
cert-path: /home/none
url: http://localhost:2375
port-range-start: 20000
apps:
- name: app
display-name: app
description: A shiny app
docker-cmd: ["R", "-e", "mypackage::run_shiny_app()"]
docker-image: mypackagecontainer
docker-network: "host"
3. I start the shinyProxy server with:
java -jar shinyproxy-1.0.2.jar
It results in a 'ShinyProxyException: Container did not respond in time’
If i remove docker-network: "host"
, the app runs normally without errors but i can’t have access to the local db.
when i do:
sudo docker run --net=host -it -p 3838:3838 mypackagecontainer
All is working correctly and i have access to the database.
Questions:
- How to avoid the error when i add
? - How to configure the application.yml to have access to the external db “xxxxx.x.fr:5432” for exemple ?
