I imported the Containerproxy project in to my local eclipse and the plan is to modify the index.html to include our references and add context to that page. But when I try to build the project in eclipse, pom.xml is missing a lot of reference (keycloak, kerbos) and after adding them, I am getting a compile time error in [AbstractDockerBackend.java] file on line 74
builder.dockerCertificates(DockerCertificates.builder().dockerCertPath(Paths.get(confCertPath)).build().orNull());
error refernecing to com.google.common.base.Optional missing reference and fix in in the build path
Can you guys help
Thank you
Nandan
