Hi @ckluss,
If you use the openanalytics/shinyproxy-demo
image (e.g. when working through the getting started guide at http://www.shinyproxy.io/getting-started/), it allows to see the group based authorization at work:
- when you log in as user ‘tesla’ (password ‘password’) who is part of the scientists user group, you will see two applications;
- if you log in as user ‘gauss’ (password ‘password’) who is part of the mathematicians user group, you will see only one application
This authorization logic is configured in the apps
block of the default application.yml
(full source at https://github.com/openanalytics/shinyproxy/blob/master/src/main/resources/application-demo.yml):
apps:
- name: 01_hello
docker-cmd: ["R", "-e shinyproxy::run_01_hello()"]
docker-image: openanalytics/shinyproxy-demo
groups: scientists, mathematicians
- name: 06_tabsets
docker-cmd: ["R", "-e shinyproxy::run_06_tabsets()"]
groups: scientists
- for the
01_hello
application you see groups: scientists, mathematicians
- for the
06_tabsets
application you only see groups: scientists
The definition of which users belong to which groups is done in the LDAP directory.
Hope this helps,
