Hello I am trying to test out Shiny Proxys LDAP integration. Instead of using forumsys as a test I am using zflex as shown below:
LDAP Server Connection Info:
Server: www.zflexldap.com
Port: 389
Bind DN: cn=ro_admin,ou=sysadmins,dc=zflexsoftware,dc=com
Bind Password: zflexpass
If you have needs that requires updating the attributes and adding more, then you need to register and obtain a special access ID - with elevated privileges. A special OU will be setup for your organization.
Recommend trying out our zFlex LDAP Browser to view the TDS Directory Tree to find other users.
Other Users IDs and their passwords are:
•uid=guest1,ou=users,ou=guests,dc=zflexsoftware,dc=com ◦guest1password
•uid=guest2,ou=users,ou=guests,dc=zflexsoftware,dc=com ◦guest2password
•uid=guest3,ou=users,ou=guests,dc=zflexsoftware,dc=com ◦guest3password
Each user (and others) have CN,SN, GivenName, EmployeeType and email to form a fully qualified LDAP Entry.
from link: http://www.zflexldapadministrator.com/index.php/blog/82-free-online-ldap
My configuration settings below are:
ldap:
url: ldap://www.zflexldap.com:389/dc=zflexsoftware,dc=com
user-dn-pattern: uid={0}
group-search-base:
group-search-filter: (uniqueMember={0})
manager-dn: cn=ro_admin,ou=sysadmins,dc=zflexsoftware,dc=com
manager-password: zflexpass
I am able to run Shiny Proxy, however, every time I enter the credentials below I am getting a Authentication failure:
username: guest1
password: guest1password
What am I doing wrong?
~Thanks
