Hi, I’m running ShinyProxy on Ubuntu 16.04.5 LTS (xenial) server on an Amazon EC2 instance, and I’m trying to get HTTPS/TLS communication between ShinyProxy and my Docker containers so that I can embed them in iframes. (I am using Apache2.)
However, I currently can’t do that because my setup has some issue communicating over HTTPS/TLS.
I attempted to configure ShinyProxy and Docker to communicate over TLS/HTTPS; for Docker I followed the steps here: https://docs.docker.com/engine/security/https/#create-a-ca-server-and-client-keys-with-openssl and for ShinyProxy I configured as per the settings under “Docker” in the “Container Back-ends” section here: https://www.shinyproxy.io/configuration/
The override.conf file for my Docker setup is below (and I’ve re-installed/re-built ShinyProxy with these settings in place):
[Service]
ExecStart=
ExecStart=/usr/bin/dockerd -H fd:// -D -H tcp://127.0.0.1:2376
Environment=“DOCKER_OPTS=-H 127.0.0.1:2376 -H unix:///var/run/docker.sock --tlsverify --tlscacert=/etc/docker/ssl/ca.pem --tlscert=/etc/docker/ssl/cert.pem --tlskey=/etc/docker/ssl/key.pem”
My ShinyProxy application.yml configuration file relevant sections are below:
authentication: none
cert-path: ~/.docker
url: http:// 127.0.0.1:2376
container-protocol: https
port-range-start: 20000
port-range-end: 20100
(In the actual config file, and throughout this post, there is no space between http:// and 127.0.0.1; I’m not sure how to prevent auto-generation of links in this forum.)
The URL is http, but the container-protocol is https because after a great deal of experimentation, this setup allowed ShinyProxy to actually spin up, and I can connect to the ShinyProxy :8080 landing page.
However, when I click on any of the apps on the landing page, ShinyProxy produces the following in the terminal:
2018-08-30 17:23:51.008 INFO 15537 — [ XNIO-2 task-4] c.s.docker.client.DefaultDockerClient : Starting container with Id: 05fc8e1d101cff4e0d75209376c87b285177f323525f0fbaad2b4dcfc910b934
2018-08-30 17:23:53.337 WARN 15537 — [ XNIO-2 task-4] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (2/10): https:// localhost:20000
Repeat another 8 times until:
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is eu.openanalytics.containerproxy.ContainerProxyException: Container did not respond in time
When I try this through the default http container-protocol, everything works exactly as expected.
I’m wondering if this is some issue with authentication: none and HTTPS interaction, or if there is something wrong with my configuration; any advice is appreciated!
Thanks for your time!
