I’m trying to add environment variables to each app following the instruction on Shinyproxy.io (Configuration -> Apps -> Note), which says should specify variables in the format of VAR1=VAL1 VAR2=VAL2
. However, this doesn’t work. I ended up using the following format:
docker-env:
VAR1: VALUE1
VAR2: VALUE2
This works fine in my setup.
