Shinyproxy, using wrappers for shiny (semantic, bs4dash)
is it supported to use other wrappers or dashboards in shinyproxy? There are many like flexdashboard, semantic, tabler or bs4dash but I cannot make my app working using above ones (error 500 time out), for blank shiny it works perfectly.
Thanks!
hi @awwoj, yes normally everything is supported. Could you check the exact error message you get? This might help. Possibly some packages are missing from the docker image?
