We are using ShinyProxy to host some of our Shiny Apps and they’re doing great. Thanks to its success, we are asked the possibility of integrating our work into a portal and to access ShinyProxy via Single sign-on. We have been experimenting successfully with the different authentication mechanisms supported by ShinyProxy (simple, ldap, social) but it seems as if the only flow possible is to provide the login credentials via the ShinyProxy login page which then is able to delegate authentication via the configuration settings in application.yml
. Is the other-way-around scenario possible where the user logs in to a portal general login page and where these credentials can be propagated to the ShinyProxy app bypassing the login page if the user is already authenticated upfront?
Many thanks for your feedback!
Stephane
