Hi Tobias
Thanks for your reply. I think I’m making progress; here is what I have so far:
First, I bring up my neo4j container with docker-compose, and create the network “impi_default”.
The shiny app is run in a container called anima.
I have specified the following in the application.yml
file
- name: anima
display-name: anima
description: ANIMA GUI interface
docker-cmd: ["R", "-e shinyproxy::runApp('/home/rstudio/common/ANIMA_Apps/ANIMA_GUI3_new.R')"]
docker-image: anmiatest/anima:v15
docker-network-connection: [ "impi-default" ]
docker-volumes: ["/Users/armindeffur/ANIMA/ANIMA_IMPI/data/source_data:/home/rstudio/source_data","/Users/armindeffur/ANIMA/ANIMA_IMPI/scripts:/home/rstudio/scripts","/Users/armindeffur/ANIMA/ANIMA_IMPI/output:/home/rstudio/output","/Users/armindeffur/ANIMA/common:/home/rstudio/common"]
#docker-env-file: neo4j.env
groups: scientists, mathematicians
When I try to launch the shiny app from the web interface this results in
Status code: 500
Message: Container did not respond in time
I suspect I am using the wrong command to launch the shiny app?
Many thanks for your help,
Armin
