After I deployed my application, I can access the shinyProxy.
I disabled the SELINUX=disabled. But I still can not access the app.
############ application.yml
authentication: none
internal-networking: false
display-name: JPGM
container-cmd: [“R”, “-e”, “shiny::runApp(’/home/JPGM’)”]
container-image: jpgm -
display-name: Euler’s number
container-cmd: [“R”, “-e”, “shiny::runApp(’/root/euler’)”]
container-image: euler -
container-cmd: [“R”, “-e”, “shinyproxy::run_01_hello()”]
container-network: sp-example-net
######################################### dockerfile
FROM openanalytics/r-base
MAINTAINER Yang Chen “ychen10@umass.edu”
system libraries of general use
sudo
pandoc
pandoc-citeproc
libcurl4-gnutls-dev
libcairo2-dev
libxt-dev
libssl-dev
libssh2-1-dev
libssl1.0.0
system library dependency for the euler app
libmpfr-dev
basic shiny functionality
RUN R -e “install.packages(c(‘shiny’, ‘rmarkdown’), repos=‘https://cloud.r-project.org/’)”
RUN R -e “install.packages(c(‘shinyBS’, ‘shinyjs’), repos=‘https://cloud.r-project.org/’)”
RUN R -e “install.packages(c(‘foreach’, ‘RColorBrewer’), repos=‘https://cloud.r-project.org/’)”
RUN R -e “install.packages(c(‘doParallel’, ‘fda’), repos=‘https://cloud.r-project.org/’)”
RUN R -e “install.packages(c(‘ggplot2’, ‘tidyr’), repos=‘https://cloud.r-project.org/’)”
RUN R -e “install.packages(‘plyr’ , repos=‘https://cloud.r-project.org/’)”
RUN useradd ec2-user
copy the app to the image
RUN mkdir /home/JPGM
COPY jpgm /home/JPGM/
RUN chmod -R 777 /home/JPGM
RUN chown -R ec2-user:ec2-user /home/JPGM
EXPOSE 80
EXPOSE 8080
Error
Status code: 500
Message: Failed to start container
Stack Trace:
eu.openanalytics.containerproxy.ContainerProxyException: Failed to start container
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.startProxy(AbstractContainerBackend.java:113)
at eu.openanalytics.containerproxy.service.ProxyService.startProxy(ProxyService.java:213)
at eu.openanalytics.shinyproxy.controllers.AppController.getOrStart(AppController.java:109)
at eu.openanalytics.shinyproxy.controllers.AppController.startApp(AppController.java:68)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:209)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:136)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:870)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:776)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:991)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:925)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:978)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:881)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:855)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:64)
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:94)
at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:159)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:336)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.spotify.docker.client.exceptions.DockerException: java.util.concurrent.ExecutionException: javax.ws.rs.ProcessingException: java.io.IOException: Permission denied
at com.spotify.docker.client.DefaultDockerClient.propagate(DefaultDockerClient.java:2846)
at com.spotify.docker.client.DefaultDockerClient.request(DefaultDockerClient.java:2721)
at com.spotify.docker.client.DefaultDockerClient.createContainer(DefaultDockerClient.java:740)
at com.spotify.docker.client.DefaultDockerClient.createContainer(DefaultDockerClient.java:722)
at eu.openanalytics.containerproxy.backend.docker.DockerEngineBackend.startContainer(DockerEngineBackend.java:83)
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.doStartProxy(AbstractContainerBackend.java:129)
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.startProxy(AbstractContainerBackend.java:110)
… 87 more
Caused by: java.util.concurrent.ExecutionException: javax.ws.rs.ProcessingException: java.io.IOException: Permission denied
at java.util.concurrent.CompletableFuture.reportGet(CompletableFuture.java:357)
at java.util.concurrent.CompletableFuture.get(CompletableFuture.java:1895)
at com.spotify.docker.client.DefaultDockerClient.request(DefaultDockerClient.java:2719)
… 92 more
Caused by: javax.ws.rs.ProcessingException: java.io.IOException: Permission denied
at org.glassfish.jersey.apache.connector.ApacheConnector.apply(ApacheConnector.java:481)
at org.glassfish.jersey.apache.connector.ApacheConnector$1.run(ApacheConnector.java:491)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at jersey.repackaged.com.google.common.util.concurrent.MoreExecutors$DirectExecutorService.execute(MoreExecutors.java:299)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:112)
at jersey.repackaged.com.google.common.util.concurrent.AbstractListeningExecutorService.submit(AbstractListeningExecutorService.java:50)
at jersey.repackaged.com.google.common.util.concurrent.AbstractListeningExecutorService.submit(AbstractListeningExecutorService.java:37)
at org.glassfish.jersey.apache.connector.ApacheConnector.apply(ApacheConnector.java:487)
at org.glassfish.jersey.client.ClientRuntime.lambda$null$3(ClientRuntime.java:187)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:272)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:268)
at org.glassfish.jersey.internal.Errors.process(Errors.java:316)
at org.glassfish.jersey.internal.Errors.process(Errors.java:298)
at org.glassfish.jersey.internal.Errors.process(Errors.java:268)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:312)
at org.glassfish.jersey.client.ClientRuntime.lambda$createRunnableForAsyncProcessing$4(ClientRuntime.java:163)
… 3 more
Caused by: java.io.IOException: Permission denied
at jnr.unixsocket.UnixSocketChannel.doConnect(UnixSocketChannel.java:127)
at jnr.unixsocket.UnixSocketChannel.connect(UnixSocketChannel.java:136)
at jnr.unixsocket.UnixSocketChannel.connect(UnixSocketChannel.java:223)
at com.spotify.docker.client.UnixConnectionSocketFactory.connectSocket(UnixConnectionSocketFactory.java:85)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:373)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
at org.glassfish.jersey.apache.connector.ApacheConnector.apply(ApacheConnector.java:435)
… 21 more
Best regards
