Hi Team,
this app is great, thank you for developing it!
I’m trying to add custom shiny applications to a containerized docker engine based on this tutorial: https://github.com/openanalytics/shinyproxy-config-examples/tree/master/02-containerized-docker-engine
In this case the shinyproxy.jar is also containerized and communicates on a bridge network with the apps (in an other image). The tutorial is straightforward and works flawlessly for the demo applications which are built into the shinyproxy-demo image already. But I’m not able to add more apps…
In this scenario, the apps have to be converted into shinyproxy functions (if I understood correctly), like shinyproxy::run_01_hello(). This is done via the [shinyproxy_0.0.1.tar.gz] installation inside the shinyproxy-demo image (R CMD INSTALL …tar.gz). It copies the files from the site-library/shiny/example folder to a temp folder.
I added new app.R files to the image, into the site-library folder. The build runs successfully, apps are converted and referenced in the application.yml. The new apps are listed but not loaded… Probably I missed something during the package installation when apps are converted into shinyproxy functions…
If anyone…
Thanks in advance,
Imre
