Hi everyone,
I’ve been trying to run the apache zeppelin example from here on my local machine: https://github.com/openanalytics/useR-2019-docker-for-data-science/tree/master/shinyproxy-docker-compose
I’ve encountered two problems that I have not been able to solve, possibly for lack of knowledge how to configure shinyproxy or spring.
problem 1: using the template simple authentication of zeppelin in the shiro.ini file I get an error from spring boot’s StrictHttpFirewall, preventing the zeppelin docker from running at all since it tries to pass a jsessionid in the url ( ;JSESSIONID=....
) which is regarded as not secure from spring. I’ve tried several ways of trying to force cookie useage (which supposedly fixes this), but havent been able to get it work.
I saw that spring’s api has a function to allow semicolons (https://docs.spring.io/spring-security/site/docs/4.2.12.RELEASE/apidocs/org/springframework/security/web/firewall/StrictHttpFirewall.html#setAllowSemicolon-boolean-) but I’m not sure how to set this in the shinyproxy config without modifying shinyproxy code itself.
Regardless of this first problem I’d also run into problem 2:
To get here I deleted shiro.ini to remove authentication from zeppelin.
The zeppelin header loads (with menu buttons etc), however when it tries to load a notebook, home.html, or any other file from its own zeppelin docker container, the springframework seems to catch the request and redirect it to within the shinyproxy docker container where those files dont exist:
shinyproxy_1 | 2019-08-20 15:00:11.407 ERROR 1 --- [ XNIO-2 task-8] io.undertow.request : UT005023: Exception handling request to /app_direct/zeppelin_notebook/app/home/home.html
shinyproxy_1 |
shinyproxy_1 | org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.IllegalArgumentException: Unknown proxy spec: home
This happens for several files, also when trying to click any of the menu items. I’ve omitted the full stacktrace, but I can post it if needed.
Other shiny or dash applications (the sample ones) run just fine.
Mac OS X 10.14.3, Docker Desktop 2.1.0.1 for mac, shinyproxy 2.3.0
Thanks for any help for this!
Below the relevant config files:
application.yml
logo-url: file:///templates/logo.png
template-path: /templates/2col
favicon-path: /templates/favicon.png
port: 80
heartbeat-timeout: 60000
container-wait-time: 30000
admin-groups: admins
- name: jack
password: password
groups: admins
- name: jeff
password: password
cert-path: /home/none
- id: 01_hello
container-network: sp-example-net
- id: 06_tabsets
display-name: Tabset Application
- id: dash-demo
display-name: Dash Application
description: Application which demonstrates the basics of a Dash app
container-cmd: ["python", "app.py"]
port: 8050
container-image: openanalytics/shinyproxy-dash-demo
- id: zeppelin_notebook
display-name: Zeppelin Notebook
description: Apache Zeppelin Official Docker
container-image: apache/zeppelin:0.8.1
container-volumes: [ "/tmp/zeppelin/#{proxy.userId}/notebook:/zeppelin/notebook", "/tmp/zeppelin/#{proxy.userId}/logs:/zeppelin/logs", "/tmp/zeppelin/conf:/zeppelin/conf" ]
spring:
servlet:
session:
cookie:
http-only: true
tracking-modes: cookie
docker-compose.yml
version: '3.7'
services:
shinyproxy:
image: shinyproxy
user: root:root
hostname: shinyproxy
restart: unless-stopped
volumes:
- /var/run/docker.sock:/var/run/docker.sock:rw
ports:
- 80:80
- 8080:8080
networks:
- sp-example-net
networks:
sp-example-net:
ipam:
config:
- subnet: 192.168.11.0/24
Dockerfile
FROM openjdk:8-jre
RUN mkdir -p /opt/shinyproxy/
COPY /archive/shinyproxy/shinyproxy-2.3.0.jar /opt/shinyproxy/shinyproxy.jar
COPY /layout/templates templates
WORKDIR /opt/shinyproxy/
CMD ["java", "-jar", "shinyproxy.jar"]
