Hi all,
I’m trying to get a very simple ShinyProxy setup working for testing purposes, but I keep running into a strange networking issue and would really appreciate some advice.
My Setup:
- I’m using ShinyProxy (openanalytics/shinyproxy:2.6.1) via Docker Compose on Linux.
- My app is just a dummy/test R Shiny app (shinyproxy-apps) – nothing special, just the classic slider + text output to prove the concept.
- I mount the Docker socket into the ShinyProxy container, as recommended.
- I followed all the usual guides and docs.
Problem:
- When I start ShinyProxy, it creates its own default network.
- But when I open an app via the ShinyProxy web UI (after logging in), the spawned Shiny app container always ends up on the default bridge network instead of the network that ShinyProxy is running on.
- This means ShinyProxy cannot reach the app container by hostname, and I always get the “container did not respond in time” error.
I tried following:
- Using the latest versions of Docker, Docker Compose, and ShinyProxy
- Downgrading Docker and ShinyProxy to older versions (still the same result)
- Setting
internal-networking: true/falsein application.yml - Explicitly defining a custom Docker network and assigning both ShinyProxy and the apps to it in both
docker-compose.ymlandapplication.yml - Removing all custom network config and letting everything use the default bridge network
- Cleaning up all old containers, images, and networks, rebooting, trying again
- Playing with the
networkparameter and all other Docker/Compose options - Different combinations of ShinyProxy and app image versions
No matter what I try, the app containers are always attached only to the default bridge network, not the network that ShinyProxy uses.
Is this a known issue with recent Docker, Compose, or ShinyProxy versions? What is the correct way to ensure that app containers always end up on the same network as the ShinyProxy container so hostname routing works? Is there something basic I might be missing, or a new best practice for recent releases?
docker-compose.yml:
version: "3"
services:
shinyproxy:
image: openanalytics/shinyproxy:2.6.1
container_name: shinyproxy-net
user: root
ports:
- 8080:8080
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- /home/xxxx/r-shiny/application.yml:/opt/shinyproxy/application.yml
restart: unless-stopped
application.yml:
title: OpenAnalytics Shiny Proxy
- name: test1
password: test
groups: [admins]
- id: helloworld
display-name: Hello World App
container-image: shinyproxy-apps-reveal
container-cmd: ["R", "-e", "shiny::runApp('/helloworld', host='0.0.0.0', port=3838)"]
container-port: 3838
container-wait-time: 60000
Dockerfile:
FROM rocker/shiny:4.2.0
COPY helloworld /helloworld
COPY histogram /histogram
# Instaliraj pakete ako treba:
RUN R -e "install.packages(c('shiny'))"
Thanks!
Regards,
Nikola
