Hi all,
I am trying to set up a persistent SQLite database for my Shiny application deployed via Shinyproxy with Docker Swarm. The app worked fine before without database. However, after adding the line container-volumes:["/db:/database"] to mount my SQLite file from the host server into the container, it continues to give me the error below. The directory db is present on my server. Permissions also seem to be fine. What could be the issue here? Attached also my application.yml file.
Error:
Application.yml file:
title: My App
container-wait-time: 30000
heartbeat-timeout: 60000
admin-groups: admins
- name: admin
password: admin
groups: admins - name: test
password: test
groups: admins
container-backend: docker-swarm
container-memory-request: 200M
container-memory-limit: 700M
container-cpu-limit: 0.7
- id: myapp
display-name: myapp
container-cmd: [“R”, “-e”, “shiny::runApp(’/root/myapp’, host=‘0.0.0.0’, port=3838)”]
container-image: username/image
container-volumes: ["/db:/database"]
access-groups: admins
container-network: sp-net
useForwardHeaders: true # this is very important to make the AWS Cognito auth works
spring:
servlet:
multipart:
max-file-size: 1000MB
max-request-size: 1000MB
