Hi all -
I believe I have everything configured properly to use AWS cognito on an ec2 machine running ubuntu. I have a working shinyproxy installation, so the only issue is getting openID to work. This is my current config file:
openid:
auth-url: https://shinyproxy.auth.us-east-2.amazoncognito.com/oauth2/author$
token-url: https://shinyproxy.auth.us-east-2.amazoncognito.com/oauth2/token
jwks-url: https://cognito-idp.us-east-2.amazonaws.com/us-east-2_Uphts82FW/.$
client-id: ***
client-secret: ***
My callback URL is:
https://report.princetontradestudy.org/login/oauth2/code/shinyproxy
I have a load balancer running that is redirecting traffic on port 80 to port 8080. The AWS Cognito will only accept HTTPS callback URLs, so I don’t know if that’s the problem. When I manually run the AWS login command using this URL:
https://shinyproxy.auth.us-east-2.amazoncognito.com/login?response_type=code&client_id=6m7cnh72b09h2cqq8032ldl38l&redirect_uri=https://report.princetontradestudy.org:8080/login/oauth2/code/shinyproxy
I get the following response when I try to log in:
Any help much appreciated!
