I’m trying to authenticate via Azure B2C. Everything works fine until the request is forwarded to the org.springframework.security.oauth2.client.authentication.OAuth2LoginAuthenticationProvider.
When this event occurs, shinyproxy repeats the same query forever.
My Logfile:
Checking match of request : '/login/oauth2/code/shinyproxy'; against '/login/oauth2/code/*'
Request is to process authentication
Authentication attempt using org.springframework.security.oauth2.client.authentication.OAuth2LoginAuthenticationProvider
Authentication attempt using org.springframework.security.oauth2.client.oidc.authentication.OidcAuthorizationCodeAuthenticationProvider
My application.yml:
authentication: openid
useForwardHeaders: true
openid:
auth-url: https://xxxx.b2clogin.com/xxx.onmicrosoft.com/oauth2/v2.0/authorize?p=b2c_xxx
token-url: https://xxx.b2clogin.com/xxx.onmicrosoft.com/oauth2/v2.0/token?p=b2c_xxx
jwks-url: https://xxx.b2clogin.com/xxx.onmicrosoft.com/discovery/v2.0/keys?p=b2c_xxx
logout-url: https://xxx.b2clogin.com/xxx.onmicrosoft.com/oauth2/v2.0/logout?p=b2c_xxx&post_logout_redirect_uri=http://localhost:18080
client-id: xxx
client-secret: xxx
