Backend error when uploading package
I face the following backend error when uploading a package.
Note that I am using a custom image with openjdk 24.0.1.
The odd thing is that despite the error (appearing both in the frontend and backend), the package is added to the repository. Yet I am unsure if it is actually valid or a broken entry (didn’t attempt a download yet since I am having other unrelated issues with accessing the public repo).
 2025-06-02 08:17:53.625 825860 [http-nio-8080-exec-8] ERROR traceId=6227306d-0516-407c-ad35-247b18d51174 e.o.r.b.a.v.c.ApiV2ErrorController : RequestURI: /server/api/v2/manager/r/submissions                                     │
│ 2025-06-02 08:17:53.625 825860 [http-nio-8080-exec-8] ERROR traceId=6227306d-0516-407c-ad35-247b18d51174 e.o.r.b.a.v.c.ApiV2ErrorController : Query parameters: repository=test&generateManual=true&replace=false&binary=false     │
│ 2025-06-02 08:17:53.627 825862 [http-nio-8080-exec-8] ERROR traceId=6227306d-0516-407c-ad35-247b18d51174 e.o.r.b.a.v.c.ApiV2ErrorController : Exception: com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Exp │
│     at com.google.gson.Gson.fromJson(Gson.java:1238)        │
│     at com.google.gson.Gson.fromJson(Gson.java:1137)        │
│     at com.google.gson.Gson.fromJson(Gson.java:1047)        │
│     at com.google.gson.Gson.fromJson(Gson.java:982)        │
│     at eu.openanalytics.rdepot.r.synchronization.RRepositorySynchronizer.getRemoteState(RRepositorySynchronizer.java:151)        │
│     at eu.openanalytics.rdepot.r.synchronization.RRepositorySynchronizer.synchronizeRepository(RRepositorySynchronizer.java:183)        │
│     at eu.openanalytics.rdepot.r.synchronization.RRepositorySynchronizer.storeRepositoryOnRemoteServer(RRepositorySynchronizer.java:125)        │
│     at eu.openanalytics.rdepot.r.synchronization.RRepositorySynchronizer.storeRepositoryOnRemoteServer(RRepositorySynchronizer.java:103)        │
│     at eu.openanalytics.rdepot.r.synchronization.RRepositorySynchronizer.storeRepositoryOnRemoteServer(RRepositorySynchronizer.java:58)        │
│     at eu.openanalytics.rdepot.base.synchronization.RepositorySynchronizer.storeRepositoryOnRemoteServer(RepositorySynchronizer.java:50)        │
│     at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:104)        │
│     at java.base/java.lang.reflect.Method.invoke(Method.java:565)
Hi @pat-s,
Can you share your manager and repo config?
Do you still have the logs somewhere? It looks like part of the trace was cut off (third line ending in Exp looks like there should be more.
Daan
@dseynaeve
I only copied what I assumed are the relevant log parts. Everything else seemed like an unhelpful Java backtrace.
I can reproduce it at anytime, but again, not sure what you’re actually looking for :slight_smile:
Here’s the complete application.yml:
allowed-origin: "*"
api-token:
  secret: ${API_TOKEN_SECRET}
  issuer: RDepot
  audience:
    - RDepot
  lifetime: 5000
access-token:
  lifetime-default: 30
  lifetime-configurable: true
  length: 32
  allowed-characters: abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789
generate-manuals: true
declarative: false
deleting:
  repositories:
    enabled: true
  packages:
    enabled: true
repository-snapshots: false
default-user-configuration:
  language: en-US
  theme: light
  page-size: 10
  supported-languages:
    - en-US
  supported-themes:
    - light
    - dark
replacing:
  packages:
    enabled: true
    max-size: 10MB
    max-history: 10
  pattern:
    console: "%d{yyyy-MM-dd HH:mm:ss.SSS} %-4r [%t] %5p traceId=%X{traceIdMDC} %c{1} : %m %n"
    file: "%d{yyyy-MM-dd HH:mm:ss.SSS} %-4r [%t] %5p traceId=%X{traceIdMDC} %c{1} : %m %n"
  level:
    root: INFO
    eu:
      openanalytics:
        rdepot: INFO
    liquibase:
      parser: INFO
    org:
      springframework:
        web:
          filter:
            CommonsRequestLoggingFilter: INFO
# Email related properties
email:
  enabled: false
  password:
  username:
  smtp:
    host:
    port:
    auth:
    starttls:
# Authentication related properties
app:
  simple:
      - login: admin
        password: ${PASSWORD}
    default:
      admins:
        - admin
  servlet:
    context-path: /server
message:
  source:
    basename: i18n/messages
entitymanager:
  packages:
    to:
      scan:
        - eu.openanalytics.rdepot.base.entities
        - eu.openanalytics.rdepot.r.entities
        - eu.openanalytics.rdepot.python.entities
package:
  version:
    max-numbers: 10
  upload:
    dir: /opt/rdepot
  rVersions:
    - 4.2
    - 4.3
    - 4.4
    - 4.5
  architectures:
    - x86_64
    - arm64
  distributions:
    - centos8
    - rhel9
    - opensuse155
    - focal
    - jammy
    - noble
    - bullseye
    - bookworm
  python:
    hashFunctions:
      - md5
      - sha1
      - sha224
      - sha256
      - sha384
      - sha512
  repository:
    generation:
      dir: /opt/rdepot/generated
    validation-name-regex:
      general: ".+"
      technology:
        python: "[A-Za-z0-9\\-_.~]+"
        r: "[A-Za-z0-9 \\-_.]+"
error:
  whitelabel:
    enabled: false
management:
  endpoints:
    enabled-by-default: false
    web:
      exposure:
        include: "health"
  endpoint:
    health:
      enabled: true
  metrics:
    web:
        request:
          autotime:
            enabled: false
springdoc:
  pathsToMatch: /api/v2/**
  api-docs:
    path: /v2/api-docs
  swagger-ui:
    path: /docs/api.html
    disable-swagger-default-url: true
    url: /v2/api-docs
    display-query-params: true
  default-produces-media-type: application/json
#storage related properties
local-storage:
  max-request-size: 10
storage:
  implementation: local
# Database related properties
db:
  driver: org.postgresql.Driver
  url: jdbc:postgresql://rdepot-pgbouncer.rdepot.svc.cluster.local:5432/rdepot
  username: rdepot
  password: ${DB_PASSWORD}
# Hibernate related properties
hibernate:
  show_sql: false
  default_schema: public
# Liquibase related properties
spring:
  liquibase:
    user: rdepot
    default-schema: public
    enabled: truerdepot-backend-78dd7f884d-6zjtq
Hi @pat-s
Last week, RDepot version 2.7.0 was released.
More information can be found here: Downloads | RDepot.
Maybe this new release fixes the issue you were having?
If not, can you please specify how to reproduce this issue step-by-step?
Thank you,
Jonas
