I’m trying to configure the SAML authentication in our Shinyproxy 2.5.0. Our IT is asking for a xml with the data they need to configure something in the Identity Provider side. I saw in the documentation that “the SAML metadata of ShinyProxy is available at the /saml/metadata path (available since ShinyProxy 2.5.0)” but when I try this url (http://myserver:8080/saml/metadata) I get a 404 error.
Is that the rigth way to get the info needed for the Identity Provider configuration? If so, why do I get the 404 error?
Thanks in advance.
