Check versions and update R packages used by application in shinyproxy
Is there a way to check what versions of R packages the application on ShinyProxy server uses? And what is the best way to update the packages?
I recommand you to use the “renv” library to manage libraries in R application, is like pom.xml for java.
With renv you can use cache feature to speed up your builds for the images that shinyproxy will run.
hope this helps
ada
Thank you. Look interesting and relevant. I will try working with this package
