I have a quite large shiny application in which some constant data is loaded from db (mysql db on external server) in config.R before running of Shiny application. It works when I run docker container only, but in shinyproxy I receive the error “Container did not respond…”
But when I delete these db queries in config.R and load it by another way, then the application works, and afterthat all db queries perform well.
I really appreciate any help
My application configuration
- id: docker_app
display-name: App
description: My app
container-image: hrychaniuk/app:latest
network_mode: "host"
container-volumes: ["/var/run/mysqld/mysqld.sock:/var/run/mysqld/mysqld.sock"]
