I am getting that 500 error from the title, although when running it manually it works ad I can access the shinyApp.
As I have shiny-server installed on my server aswell I had to change the port from 3838 to 9999.
When starting the app via sudo docker run -it -p 9999:9999 vde/tirol the app starts correctly when going to http://serverIP:9999/ and I see Listening on http://0.0.0.0:9999 in the terminal.
But when I try to start it over shinyproxy via http://serverIP:8080/app_direct/tirol/ I am getting that timeout error.
application.yml:
proxy: port: 8080 authentication: none bind-adress: 127.0.0.1 container-wait-time: 60000 heartbeat-rate: 10000 heartbeat-timeout: 200000 landing-page: /app_direct/tirol/ hide-navbar: true container-backend: docker container-log-path: ./container-logs docker: url: http://localhost:2375 container-protocol: http internal-networking: false specs: - id: tirol display-name: VDE container-cmd: ["R", "-e", "shiny::runApp('root/tirol')"] container-image: vde/tirol logging: file: shinyproxy.log server: servlet.session.timeout: 3600
Dockerfile has EXPOSE 9999.
and the Rprofile has shiny.port = 9999
The log files show 30 times:
[XNIO-2 task-6] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (17/30): http://localhost:20000
before exiting with this error:
Request processing failed; nested exception is eu.openanalytics.containerproxy.ContainerProxyException: Container did not respond in time
Thanks again!
