I am able to add environment variables with to an app container via proxy.specs.container-env
. However, when I try to put multiple environment variables into proxy.specs.container-env-file
, these values are ignored. This is with shinyproxy 2.0.4 running in a Docker container. With shinyproxy < 2 I have had no problems specifying multiple variables via an env file. If needed I can provide minimal example configurations.
What might be the problem here? Is anybody using container-env-file
with a conainerized shinyproxy?
Greetings
Ralf
