I’m just getting started trying to use ShinyProxy to host a shiny app that I’ve built. I’m trying to do so running shiny proxy inside a docker container as per example set up 02 (in fact I’m deploying it from that example with a few tweaks made to the application.yml file.
The container image for the app itself builds ok and I can access it directly when spun up outside of shiny proxy.
I created the docker network and the application.yml file looks like this
I’ve checked for firewall issues as per the troubleshooting guide and that doesn’t appear to be the problem. Any suggestions would be much appreciated
Thanks Ana, I was missing the -v and the --net specification in the docker run command. I naively assumed that it would pick that information up from the application.yml.
