When trying to run a MRE for the other post in this forum, I came across a strange problem I could not fix myself.
The problem also appears identically when using the shinyproxy example images. So I guess it has nothing todo with the specific app.
The code can be found here (including instructions on what to do):
I have an image that works and looks nice.
I can also start ShinyProxy on port 3839 on the host machine with the following command:
docker run --publish 3839:8080 -v /var/run/docker.sock:/var/run/docker.sock --rm shinyproxy:latest
Looks good, too. Now when I want to start the app, ShinyProxy manages to start the app container instance (I can see this when looking at docker ps), and when opening the app container instance in a separate window it also works perfectly! But within the app window in ShinyProxy, the app will not appear and show an error instead (logs):
Container did not respond in time
output of docker ps after clicking on the app:
# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
066e1a6e8616 testapp "R -e 'shiny::runApp…" 18 seconds ago Up 17 seconds 0.0.0.0:20100->3838/tcp cool_chatelet
08144db01812 shinyproxy:latest "java -jar /opt/shin…" About a minute ago Up About a minute 0.0.0.0:3839->8080/tcp, :::3839->8080/tcp silly_bartik
What am I doing wrong?
ShinyProxy manages to successfully start the app container instance and there is no R error since I can interact with that very same app container instance without problems, but ShinyProxy would not connect to it.
Thanks, that solved the problem. For those coming here from Google / ChatGPT:
Make sure you have created a docker network with sudo docker network create sp-example-net (for example)
In application.yml, add internal-networking: true to the docker section of the proxy settings, as well as container-network: sp-example-net to the container-network property of your app section
Start with sudo docker run --publish 8080:8080 -v /var/run/docker.sock:/var/run/docker.sock:ro --rm --group-add $(getent group docker | cut -d: -f3) --net sp-example-net shinyproxy:latest
