I just did a clean install of ShinyProxy 3.1.1 updating from 2.3.0. Whenever I select one of my applications, I immediately receive a “Failed to start app” message. If I wait a moment and click try again, it works. I’ve adjusted the container-wait-time to up to 60000, but it doesn’t seem to wait. Any thoughts?
Hi, I don’t think this is caused by the container-wait-time configuration, since you immediately get the error. ShinyProxy should log why the app failed to start, can you share the logs? In addition, can you share your configuration?
