I noticed that when the connection is lost between the client and the server, shinyProxy remains idle for about 10 seconds, and then disconnects. I tried to modify heartbeat-rate in the application.yml file, but it does not change anything. Is it possible to change this value with this file ?
Hi @KZARCA,
I’m not sure what you mean by
Do you mean the shiny UI turning grey? Or the shinyproxy instance shutting down the container?
I just realized with your message that the question was not related to shinyproxy, but to shiny package itself.
