Do you have a minimal example of deploying the new customHeader authentication in ShinyProxy 3.2?
I am unclear if the header is sufficient or if a webservice is needed and how that interacts with the header (and group)
It seems we missed this post before.
Indeed adding the headers is enough, there is no need to run or configure a webservice.
As a quick example, let’s say you have the following ShinyProxy config:
title: My ShinyProxy
authentication: customHeader
If you try to access ShinyProxy in a browser, you’ll be redirect to the “auth error” page.
To test the authentication, you can use curl and send the correct header:
$ curl -H "REMOTE_USER: jack" localhost:8080/api/proxyspec/
{"status":"success","data":[]}
With the header, you are now authenticated as the “jack” user.
