How could I customize shinyproxy navbar, for instance: remove, change color, etc?
And how is it possible to get at the landing page my shinyapp instead of having a link to the app?
Thanks
Thanks
The html files are in the: src/main/resources/templates folder.
For your second question you could do a redirect or something like that in your index file.
Then for the changes to be reflected on your site I think you must re-run the build using
mvn -U clean install
but I am not sure if there is an easier way to see the changes on your pages, maybe somebody else here has an easier solution?
I managed to modify the template index.html by doing a redirect and rebuild shinyproxy.
And it works! Thank you very much
The downside of this approach is that the page loading takes more time to load.
As you mention, if somebodye find a easier solution, i will be glad to here it.
JPG
I’m looking for the exact same capability. I would like to see that we could create a group configuration that would state that it auto launches a single app, and that you would state what application is launched. If the user is more than 1 group, this would not apply.
eg.
groups
- group: my_product_app
auto-launch: true
app-launch: openanalytics/shinyproxy-demo
@jpg,
Hiding the navbar is possible in version 0.8.7 with a new setting hide-navbar: true
May I ask which part of the code you modify to do the redirection?
Regards
Jeff
In my case, i just added in ‘index.html’ (shinyproxy>src>main>resources>index.html) the following in the head tag:
After that, i rebuilt shinyproxy source code: mvn -U clean install
JPG
