I have tried to run Dash dashboart on ShinyProxy/ I use https://github.com/openanalytics/shinyproxy-dash-demo - and it worked.
But I changed dash on new version and it broke.
It’s works:
RUN pip install dash==0.36.0 # The core dash backend
RUN pip install dash-renderer==0.17.0 # The dash front-end
RUN pip install dash-html-components==0.13.5 # HTML components
RUN pip install dash-core-components==0.43.0 # Supercharged components
It’s not works:
RUN pip install dash==1.3.0 # The core dash backend
RUN pip install dash-renderer==1.1.0 # The dash front-end
RUN pip install dash-html-components==1.0.1 # HTML components
RUN pip install dash-core-components==1.2.0 # Supercharged components
Message: Error loading layout
