I would like to know how I can customize the Shinyproxy landing page below.
I have read somewhere on the community that the html file can be found in this folder: src/main/resources/templates but I don’t have such folder in my Linux EC2 instance.
Thanks in advance.
Max
I’m having the same issue / question. My one idea was to modify the jar file directly in the templates folder or in the containerproxy-0.8.3.jar. However, when I recompile the jar (even without any changes) the app does not load.
Any ideas for how to do this with containerproxy in particular?
Hello Maxim ! I’m absolutely sorry, I had not seen the notification of your reply…
My main issue is that I am not able to locate where to re-upload the modified login.html version.
When I do cd /usr/src I only have inside two folders: debug and kernels.
Should I be looking somewhere else ?
You don’t need to upload it, but just to put into some location on the server, and then point application.yaml’s proxy.template-path line to that chosen location.
Once again, please refer to the repository link above
