When I run my shinyproxy container with the method described here, everything works fine.
Trying to do the same with docker-compose (or, same effect, docker compose swarm) fails with authorization error on docker.sock. The file is set chown root:docker on each docker startup; when I set this to chown dieter:docker, where dieter is the user, all is well, but I have to do this after each docker startup.
I am sure that dieter is in group docker - confirmed by the working command line version. I suspect that group_add in docker-compose is the culprit, it has a bad history of being removed in earlier 3.x versions but is supposed to work now .
Any ideas for a workaround? I must use docker-compose or docker compose because additional containers will be added later.
version: '3.8'
services:
shinyproxy:
build: .
image: shinyproxy-example
container_name: shinyproxy-ex
ports:
- 8020:8080
networks:
- sp-net
# https://github.com/docker/compose/issues/4700#issuecomment-813751699
group_add:
- docker
volumes:
# Check permissions here
- /var/run/docker.sock:/var/run/docker.sock
title: Anomanor Shinyproxy
logo-url: https://menne-biomed.de/images/mennebiomed48.gif
- name: jack
password: password
groups: scientists
admin-groups: admins
landing-page: /app_direct/01_hello
- id: 01_hello
container-network: sp-net
