Hi all,
We are running ShinyProxy with docker swarm and our dashboards run okay. The only problem is that it takes longer than normal to show an individual dashboard. We tested an individual dashboard, it took 5 seconds to open with docker run and 15 seconds on ShinyProxy.
We tried to do docker inspect and saw the followings:
{"log":"2023-07-12 13:33:32.693 INFO 1 --- [ main] e.o.c.util.StartupEventListener : Started ShinyProxy 3.0.2-SNAPSHOT (ContainerProxy 1.0.2-SNAPSHOT)\n","stream":"stdout","time":"2023-07-12T13:33:32.694252384Z"}
{"log":"2023-07-12 13:33:32.694 INFO 1 --- [ main] e.o.c.service.AppRecoveryService : Recovery of running apps disabled\n","stream":"stdout","time":"2023-07-12T13:33:32.694627944Z"}
{"log":"2023-07-12 13:33:34.161 INFO 1 --- [ XNIO-1 task-1] io.undertow.servlet : Initializing Spring DispatcherServlet 'dispatcherServlet'\n","stream":"stdout","time":"2023-07-12T13:33:34.161646637Z"}
{"log":"2023-07-12 13:33:34.162 INFO 1 --- [ XNIO-1 task-1] o.s.web.servlet.DispatcherServlet : Initializing Servlet 'dispatcherServlet'\n","stream":"stdout","time":"2023-07-12T13:33:34.162514192Z"}
{"log":"2023-07-12 13:33:34.164 INFO 1 --- [ XNIO-1 task-1] o.s.web.servlet.DispatcherServlet : Completed initialization in 2 ms\n","stream":"stdout","time":"2023-07-12T13:33:34.165031827Z"}
{"log":"2023-07-12 13:33:34.183 INFO 1 --- [ XNIO-1 task-1] e.o.containerproxy.service.UserService : Anonymous user logged in [user: ebfcfeea81dd37b7f1b54ea9dd3d8c5103854b92c0c02c5a08292eca268656f]\n","stream":"stdout","time":"2023-07-12T13:33:34.183475629Z"}
{"log":"2023-07-12 13:33:38.319 INFO 1 --- [pool-2-thread-1] e.o.containerproxy.service.ProxyService : [user=ebfcfeea81dd37b7f1b54ea9dd3d8c5103854b92c0c02c5a08292eca268656f proxyId=cab46b61-b1db-476c-a396-3564df4dd763 specId=iraq-state-budget] Starting
proxy\n","stream":"stdout","time":"2023-07-12T13:33:38.3204036Z"}
{"log":"2023-07-12 13:33:43.829 WARN 1 --- [pool-2-thread-1] e.o.shinyproxy.ShinyProxyTestStrategy : [user=ebfcfeea81dd37b7f1b54ea9dd3d8c5103854b92c0c02c5a08292eca268656f proxyId=cab46b61-b1db-476c-a396-3564df4dd763 specId=iraq-state-budget] Container unresponsive, trying again (11/20): http://fb3bc4657b3e:3838\n","stream":"stdout","time":"2023-07-12T13:33:43.829375118Z"}
{"log":"2023-07-12 13:33:45.830 WARN 1 --- [pool-2-thread-1] e.o.shinyproxy.ShinyProxyTestStrategy : [user=ebfcfeea81dd37b7f1b54ea9dd3d8c5103854b92c0c02c5a08292eca268656f proxyId=cab46b61-b1db-476c-a396-3564df4dd763 specId=iraq-state-budget] Container unresponsive, trying again (12/20): http://fb3bc4657b3e:3838\n","stream":"stdout","time":"2023-07-12T13:33:45.830410778Z"}
{"log":"2023-07-12 13:33:47.831 WARN 1 --- [pool-2-thread-1] e.o.shinyproxy.ShinyProxyTestStrategy : [user=ebfcfeea81dd37b7f1b54ea9dd3d8c5103854b92c0c02c5a08292eca268656f proxyId=cab46b61-b1db-476c-a396-3564df4dd763 specId=iraq-state-budget] Container unresponsive, trying again (13/20): http://fb3bc4657b3e:3838\n","stream":"stdout","time":"2023-07-12T13:33:47.83180459Z"}
{"log":"2023-07-12 13:33:51.944 INFO 1 --- [pool-2-thread-1] e.o.shinyproxy.ShinyProxyTestStrategy : [user=ebfcfeea81dd37b7f1b54ea9dd3d8c5103854b92c0c02c5a08292eca268656f proxyId=cab46b61-b1db-476c-a396-3564df4dd763 specId=iraq-state-budget] Container responsive\n","stream":"stdout","time":"2023-07-12T13:33:51.944986132Z"}
{"log":"2023-07-12 13:33:51.974 INFO 1 --- [pool-2-thread-1] e.o.containerproxy.service.ProxyService : [user=ebfcfeea81dd37b7f1b54ea9dd3d8c5103854b92c0c02c5a08292eca268656f proxyId=cab46b61-b1db-476c-a396-3564df4dd763 specId=iraq-state-budget] Proxy activated\n","stream":"stdout","time":"2023-07-12T13:33:51.975067949Z"}
As you can see shinyproxy.ShinyProxyTestStrategy is raising warnings of Container unresponsive, trying again until it opens on the 13th try.
Anyone has any thoughts on load time and the logs warnings ?
Thank you,
Riyadh
