HI All
Does Shinyproxy work with Azure AD with different groups has anyone gotten SAML or openid to work
I was hoping to get some step by step guide of a sample yml config. getting Azure AD to work.
Thanks
HI All
Thanks
Yes, i have Azure AD working via SAML:
Not sure what you mean by groups, but role based information does come through as:
username <- Sys.getenv("SHINYPROXY_USERNAME")
usergroup<-Sys.getenv("SHINYPROXY_USERGROUPS")
you’ll have to replace the entity ID with your own in the below YAML file.
Most of the work is probably on the Azure side, setting up roles in the enterprise app.
Im getting this error Below after login
Here is my sample part of yml .
forward-headers-strategy: native
secure-cookies: true
authentication: saml
saml:
idp-metadata-url: https://login.microsoftonline.com/i have addedthe tenant ID/FederationMetadata/2007-06/FederationMetadata.xml
app-entity-id: Using the saml application ID (azure)
app-base-url: main website url
roles-attribute: http://schemas.microsoft.com/ws/2008/06/identity/claims/role
Status code: 200
Message: Incoming SAML message is invalid
Stack Trace:
org.springframework.security.authentication.AuthenticationServiceException: Incoming SAML message is invalid
at org.springframework.security.saml.SAMLProcessingFilter.attemptAuthentication(SAMLProcessingFilter.java:105)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:212)
at eu.openanalytics.containerproxy.auth.impl.saml.AlreadyLoggedInFilter.doFilter(AlreadyLoggedInFilter.java:50)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:186)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:155)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:117)
at org.springframework.security.web.header.HeaderWriterFilter.doHeadersAfter(HeaderWriterFilter.java:92)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:77)
at org.springframework.security.saml.metadata.MetadataDisplayFilter.doFilter(MetadataDisplayFilter.java:84)
at org.springframework.security.saml.metadata.MetadataGeneratorFilter.doFilter(MetadataGeneratorFilter.java:87)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:100)
at org.springframework.boot.actuate.metrics.web.servlet.WebMvcMetricsFilter.doFilterInternal(WebMvcMetricsFilter.java:93)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:91)
at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:160)
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:370)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:836)
at org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:2019)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1558)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1449)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.opensaml.xml.security.SecurityException: SAML message intended destination endpoint did not match recipient endpoint
at org.opensaml.common.binding.decoding.BaseSAMLMessageDecoder.checkEndpointURI(BaseSAMLMessageDecoder.java:217)
at org.opensaml.saml2.binding.decoding.BaseSAML2MessageDecoder.decode(BaseSAML2MessageDecoder.java:72)
at org.springframework.security.saml.processor.SAMLProcessorImpl.retrieveMessage(SAMLProcessorImpl.java:105)
at org.springframework.security.saml.processor.SAMLProcessorImpl.retrieveMessage(SAMLProcessorImpl.java:172)
at org.springframework.security.saml.SAMLProcessingFilter.attemptAuthentication(SAMLProcessingFilter.java:85)
… 81 more
can anyone shed some light on this ?
@Philip_Wu would be possible to connect with you ?
@Philip_Wu for Azure side Enterprise app
