Greetings,
I’m using SAML (Auth0.com) user verification and I have a problem here that I don’t know how to solve.
SAML verification works just fine but I have a problem with email verification error.
Email verification is required when the user creates the account and if he does verification before log-in it works fine. But if he tries to log in immediately without confirmation in the email Shinyproxy doesn’t return page with error description - that’s what I want - (return from Auth0 rule) but displays page with java error 200 Error validating SAML message.
How to handle this error and redirect user to some other page where I will give him information on what to do?
thank you in advance!
Miroslav
Auth0 rule for Email Verification
function (user, context, callback) {
if (!!user.email_verified) {
return callback(null, user, context);
const ManagementClient = require('auth0@2.23.0').ManagementClient;
const management = new ManagementClient({
token: auth0.accessToken,
domain: auth0.domain
const emailVerificationParams = {
user_id: user.user_id,
client_id: context.clientID,
management.sendEmailVerification(emailVerificationParams, function (err) {
if (err) {
return callback(err);
return callback(new UnauthorizedError('Please verify your email before logging in. An email has been sent to you with instructions. After verifying please logout and login again.'));
application.yml
authentication: saml
saml:
idp-metadata-url: https://LINK.auth0.com/samlp/metadata/KEY
app-entity-id: urn:LINK.auth0.com
app-base-url: http://localhost:8080
name-attribute: http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress
roles-attribute: http://schemas.auth0.com/rolez
logout-url: https://LINK.auth0.com/v2/logout?client_id=KEY&returnTo=http://localhost:8080
Java run
Spring Boot (v2.3.4.RELEASE)
2021-02-11 23:37:50.146 INFO 12836 --- [ main] .s.d.r.c.RepositoryConfigurationDelegate : Multiple Spring Data modules found, entering strict repository configuration mode!
2021-02-11 23:37:50.151 INFO 12836 --- [ main] .s.d.r.c.RepositoryConfigurationDelegate : Bootstrapping Spring Data JPA repositories in DEFERRED mode.
2021-02-11 23:37:50.188 INFO 12836 --- [ main] .s.d.r.c.RepositoryConfigurationDelegate : Finished Spring Data repository scanning in 29ms. Found 0 JPA repository interfaces.
2021-02-11 23:37:50.200 INFO 12836 --- [ main] .s.d.r.c.RepositoryConfigurationDelegate : Multiple Spring Data modules found, entering strict repository configuration mode!
2021-02-11 23:37:50.201 INFO 12836 --- [ main] .s.d.r.c.RepositoryConfigurationDelegate : Bootstrapping Spring Data Redis repositories in DEFAULT mode.
2021-02-11 23:37:50.222 INFO 12836 --- [ main] .s.d.r.c.RepositoryConfigurationDelegate : Finished Spring Data repository scanning in 13ms. Found 0 Redis repository interfaces.
2021-02-11 23:37:51.900 WARN 12836 --- [ main] io.undertow.websockets.jsr : UT026010: Buffer pool was not set on WebSocketDeploymentInfo, the default pool will be used
2021-02-11 23:37:51.920 INFO 12836 --- [ main] io.undertow.servlet : Initializing Spring embedded WebApplicationContext
2021-02-11 23:37:51.920 INFO 12836 --- [ main] w.s.c.ServletWebServerApplicationContext : Root WebApplicationContext: initialization completed in 2698 ms
2021-02-11 23:37:52.618 INFO 12836 --- [ main] .s.m.p.AbstractReloadingMetadataProvider : New metadata succesfully loaded for 'https://LINK.auth0.com/samlp/metadata/KEY'
2021-02-11 23:37:52.620 INFO 12836 --- [ main] .s.m.p.AbstractReloadingMetadataProvider : Next refresh cycle for metadata provider 'https://LINK.auth0.com/samlp/metadata/KEY' will occur on '2021-02-12T01:37:52.271Z' ('2021-02-12T02:37:52.271+01:00' local time)
2021-02-11 23:37:52.714 INFO 12836 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/saml/login/**'], [org.springframework.security.saml.SAMLEntryPoint@35f760a4]
2021-02-11 23:37:52.714 INFO 12836 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/saml/SSO/**'], [org.springframework.security.saml.SAMLProcessingFilter@8d29719]
2021-02-11 23:37:52.723 INFO 12836 --- [ main] o.s.boot.web.servlet.RegistrationBean : Filter orderedFormContentFilter was not registered (disabled)
2021-02-11 23:37:52.824 INFO 12836 --- [ main] o.s.s.concurrent.ThreadPoolTaskExecutor : Initializing ExecutorService 'applicationTaskExecutor'
2021-02-11 23:37:52.867 INFO 12836 --- [ task-1] o.hibernate.jpa.internal.util.LogHelper : HHH000204: Processing PersistenceUnitInfo [name: default]
2021-02-11 23:37:52.908 WARN 12836 --- [ main] JpaBaseConfiguration$JpaWebConfiguration : spring.jpa.open-in-view is enabled by default. Therefore, database queries may be performed during view rendering. Explicitly configure spring.jpa.open-in-view to disable this warning
2021-02-11 23:37:52.947 INFO 12836 --- [ task-1] org.hibernate.Version : HHH000412: Hibernate ORM core version 5.4.21.Final
2021-02-11 23:37:53.142 INFO 12836 --- [ task-1] o.hibernate.annotations.common.Version : HCANN000001: Hibernate Commons Annotations {5.1.0.Final}
2021-02-11 23:37:53.343 INFO 12836 --- [ task-1] com.zaxxer.hikari.HikariDataSource : HikariPool-1 - Starting...
2021-02-11 23:37:53.407 WARN 12836 --- [ main] o.a.h.c.protocol.ResponseProcessCookies : Invalid cookie header: "Set-Cookie: did=s%3Av0%3Ac75973d0-6cb9-11eb-9ff6-f93b72bfbcf3.ahRt9UKZ6HpnTWQ4D6Hc9UmaQcvqLN8HT9lFZScY3UE; Max-Age=31557600; Path=/; Expires=Sat, 12 Feb 2022 04:37:53 GMT; HttpOnly; Secure; SameSite=None". Invalid 'expires' attribute: Sat, 12 Feb 2022 04:37:53 GMT
2021-02-11 23:37:53.407 WARN 12836 --- [ main] o.a.h.c.protocol.ResponseProcessCookies : Invalid cookie header: "Set-Cookie: did_compat=s%3Av0%3Ac75973d0-6cb9-11eb-9ff6-f93b72bfbcf3.ahRt9UKZ6HpnTWQ4D6Hc9UmaQcvqLN8HT9lFZScY3UE; Max-Age=31557600; Path=/; Expires=Sat, 12 Feb 2022 04:37:53 GMT; HttpOnly; Secure". Invalid 'expires' attribute: Sat, 12 Feb 2022 04:37:53 GMT
2021-02-11 23:37:53.449 INFO 12836 --- [ main] e.o.c.stat.StatCollectorRegistry : Disabled. Usage statistics will not be processed.
LogoutURL: https://LINK.auth0.com/v2/logout?client_id=KEY&returnTo=http://localhost:8080
2021-02-11 23:37:53.542 INFO 12836 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: any request, [org.springframework.security.saml.metadata.MetadataGeneratorFilter@141b011a, org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter@43cbafa6, org.springframework.security.web.context.SecurityContextPersistenceFilter@2d705998, org.springframework.security.web.header.HeaderWriterFilter@4d770bcd, org.springframework.security.web.csrf.CsrfFilter@1e9d721, org.springframework.security.web.authentication.logout.LogoutFilter@1cfa7ee0, org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter@5c60f096, org.springframework.security.web.authentication.www.BasicAuthenticationFilter@538f45f1, FilterChainProxy[Filter Chains: [[ Ant [pattern='/saml/login/**'], [org.springframework.security.saml.SAMLEntryPoint@35f760a4]], [ Ant [pattern='/saml/SSO/**'], [org.springframework.security.saml.SAMLProcessingFilter@8d29719]]]], org.springframework.security.web.savedrequest.RequestCacheAwareFilter@7582a16b, org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter@5d94ac8a, org.springframework.security.web.authentication.AnonymousAuthenticationFilter@64fc6470, org.springframework.security.web.session.SessionManagementFilter@79b4cff, org.springframework.security.web.access.ExceptionTranslationFilter@5cba890e, org.springframework.security.web.access.intercept.FilterSecurityInterceptor@5f35370b]
2021-02-11 23:37:53.552 WARN 12836 --- [ main] org.thymeleaf.templatemode.TemplateMode : [THYMELEAF][main] Template Mode 'HTML5' is deprecated. Using Template Mode 'HTML' instead.
2021-02-11 23:37:53.742 INFO 12836 --- [ main] o.s.b.a.w.s.WelcomePageHandlerMapping : Adding welcome page template: index
2021-02-11 23:37:53.777 INFO 12836 --- [ task-1] com.zaxxer.hikari.HikariDataSource : HikariPool-1 - Start completed.
2021-02-11 23:37:53.822 INFO 12836 --- [ task-1] org.hibernate.dialect.Dialect : HHH000400: Using dialect: org.hibernate.dialect.MySQL8Dialect
2021-02-11 23:37:54.094 INFO 12836 --- [ task-1] o.h.e.t.j.p.i.JtaPlatformInitiator : HHH000490: Using JtaPlatform implementation: [org.hibernate.engine.transaction.jta.platform.internal.NoJtaPlatform]
2021-02-11 23:37:54.105 INFO 12836 --- [ task-1] j.LocalContainerEntityManagerFactoryBean : Initialized JPA EntityManagerFactory for persistence unit 'default'
2021-02-11 23:37:54.192 INFO 12836 --- [ main] o.s.l.c.support.AbstractContextSource : Property 'userDn' not set - anonymous context will be used for read-write operations
2021-02-11 23:37:54.426 INFO 12836 --- [ main] o.s.b.a.e.web.EndpointLinksResolver : Exposing 2 endpoint(s) beneath base path '/actuator'
2021-02-11 23:37:54.457 INFO 12836 --- [ main] io.undertow : starting server: Undertow - 2.1.4.Final
2021-02-11 23:37:54.465 INFO 12836 --- [ main] org.xnio : XNIO version 3.8.0.Final
2021-02-11 23:37:54.473 INFO 12836 --- [ main] org.xnio.nio : XNIO NIO Implementation Version 3.8.0.Final
2021-02-11 23:37:54.531 INFO 12836 --- [ main] org.jboss.threads : JBoss Threads version 3.1.0.Final
2021-02-11 23:37:54.584 INFO 12836 --- [ main] o.s.b.w.e.undertow.UndertowWebServer : Undertow started on port(s) 8080 (http)
2021-02-11 23:37:54.585 INFO 12836 --- [ main] DeferredRepositoryInitializationListener : Triggering deferred initialization of Spring Data repositories…
2021-02-11 23:37:54.586 INFO 12836 --- [ main] DeferredRepositoryInitializationListener : Spring Data repositories initialized!
2021-02-11 23:37:54.600 INFO 12836 --- [ main] e.o.c.util.StartupEventListener : Started ShinyProxy 2.4.1 (ContainerProxy 0.8.5)
2021-02-11 23:38:12.574 INFO 12836 --- [ XNIO-1 task-1] io.undertow.servlet : Initializing Spring DispatcherServlet 'dispatcherServlet'
2021-02-11 23:38:12.574 INFO 12836 --- [ XNIO-1 task-1] o.s.web.servlet.DispatcherServlet : Initializing Servlet 'dispatcherServlet'
2021-02-11 23:38:12.579 INFO 12836 --- [ XNIO-1 task-1] o.s.web.servlet.DispatcherServlet : Completed initialization in 5 ms
2021-02-11 23:38:12.586 INFO 12836 --- [ XNIO-1 task-1] o.s.s.s.m.MetadataGeneratorFilter : No default metadata configured, generating with default values, please pre-configure metadata for production use
2021-02-11 23:38:12.590 INFO 12836 --- [ XNIO-1 task-1] o.s.s.saml.metadata.MetadataGenerator : Generating metadata without signing key, KeyStore doesn't contain any default private key, or the signingKey specified in ExtendedMetadata cannot be found
2021-02-11 23:38:12.590 INFO 12836 --- [ XNIO-1 task-1] o.s.s.saml.metadata.MetadataGenerator : Generating metadata without encryption key, KeyStore doesn't contain any default private key, or the encryptionKey specified in ExtendedMetadata cannot be found
2021-02-11 23:38:12.590 INFO 12836 --- [ XNIO-1 task-1] o.s.s.s.m.MetadataGeneratorFilter : Created default metadata for system with entityID: urn:LINK.auth0.com
2021-02-11 23:38:12.635 INFO 12836 --- [ XNIO-1 task-1] o.s.security.saml.log.SAMLDefaultLogger : AuthNRequest;SUCCESS;0:0:0:0:0:0:0:1;urn:LINK.auth0.com;urn:LINK.auth0.com;;;
2021-02-11 23:38:22.976 INFO 12836 --- [ XNIO-1 task-1] colMessageXMLSignatureSecurityPolicyRule : SAML protocol message was not signed, skipping XML signature processing
2021-02-11 23:38:22.978 INFO 12836 --- [ XNIO-1 task-1] o.s.security.saml.log.SAMLDefaultLogger : AuthNResponse;FAILURE;0:0:0:0:0:0:0:1;urn:LINK.auth0.com;urn:LINK.auth0.com;;;org.springframework.security.saml.SAMLStatusException: Response has invalid status code urn:oasis:names:tc:SAML:2.0:status:Responder, status message is null
at org.springframework.security.saml.websso.WebSSOProfileConsumerImpl.processAuthenticationResponse(WebSSOProfileConsumerImpl.java:146)
at org.springframework.security.saml.SAMLAuthenticationProvider.authenticate(SAMLAuthenticationProvider.java:88)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:199)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:219)
at org.springframework.security.config.annotation.web.configuration.WebSecurityConfigurerAdapter$AuthenticationManagerDelegator.authenticate(WebSecurityConfigurerAdapter.java:534)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:205)
at com.sun.proxy.$Proxy89.authenticate(Unknown Source)
at org.springframework.security.saml.SAMLProcessingFilter.attemptAuthentication(SAMLProcessingFilter.java:92)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:212)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:186)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:155)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:117)
at org.springframework.security.web.header.HeaderWriterFilter.doHeadersAfter(HeaderWriterFilter.java:92)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:77)
at org.springframework.security.saml.metadata.MetadataGeneratorFilter.doFilter(MetadataGeneratorFilter.java:87)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:100)
at org.springframework.boot.actuate.metrics.web.servlet.WebMvcMetricsFilter.doFilterInternal(WebMvcMetricsFilter.java:93)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:91)
at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:160)
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:370)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:836)
at org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:2019)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1558)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1449)
at java.lang.Thread.run(Thread.java:748)
2021-02-11 23:38:22.979 INFO 12836 --- [ XNIO-1 task-1] e.o.containerproxy.service.UserService : Authentication failure [user: ] [error: Error validating SAML message]
web page error return
Error
Status code: 200
Message: Error validating SAML message
Stack Trace:
org.springframework.security.authentication.AuthenticationServiceException: Error validating SAML message
at org.springframework.security.saml.SAMLAuthenticationProvider.authenticate(SAMLAuthenticationProvider.java:101)
Caused by: org.springframework.security.saml.SAMLStatusException: Response has invalid status code urn:oasis:names:tc:SAML:2.0:status:Responder, status message is null
... 88 more
