we have a Shiny Dashboard with ShinyProxy behind a Nginx Reverse Proxy and receive HTTP error 503 from time to time randomly on different assets (css or js). We tried with versions of ShinyProxy from 2.3 up to 2.5. We have no load balancer, and also disabling logging as mentioned in a similar issue didn’t help.
application.yml
title: Shiny-Dashboard
logo-url: /Logo_BW.png
hide-navbar: true
heartbeat-timeout: 900000
admin-groups: dev
container-log-path: /home/shinyproxy/logs/container-logs
- name: achim
password: zyx
groups: dev
cert-path: /home/none
url: http://localhost:2375
port-range-start: 20000
- id: headers
display-name: HEADER Dev
description: HEADER Development Version
container-cmd: ["R", "-e", "HEADERDashboard::launchHEADERDashboard(log_level = 'debug')"]
container-image: header-dashboard
container-volumes: [ "/etc/shinyproxy/config/config.yml:/config.yml", "/etc/shinyproxy/config/role_config.yml:/role_config.yml" ]
container-env:
CONFIG_PATH: /
access-groups: [dev]
contextPath: /headers
servlet:
context-path: /headers
nginx configuration
location /headers {
proxy_http_version 1.1;
proxy_read_timeout 600s;
proxy_redirect off; proxy_set_header Host $http_host;
Any help is welcome.
Achim
