I’m almost loving shinyproxy… except I’ve got a failure with the current version of Docker.
I can run the docker samples from the command line, but there is a config file error when used with the new updated version of docker (on Centos 7 downloaded by yum) when run automatically.
docker version
Client:
Version: 1.13.1
API version: 1.26
Package version: docker-1.13.1-63.git94f4240.el7.centos.x86_64
Go version: go1.9.4
Git commit: 94f4240/1.13.1
Built: Fri May 18 15:44:33 2018
OS/Arch: linux/amd64
Server:
Version: 1.13.1
API version: 1.26 (minimum version 1.12)
Go version: go1.9.4
Experimental: false
The docker config files looks like:
Type=notify
NotifyAccess=all
EnvironmentFile=-/run/containers/registries.conf
EnvironmentFile=-/etc/sysconfig/docker
EnvironmentFile=-/etc/sysconfig/docker-storage
EnvironmentFile=-/etc/sysconfig/docker-network
Environment=GOTRACEBACK=crash
Environment=DOCKER_HTTP_HOST_COMPAT=1
#Environment=-H tcp://127.0.0.1:2375 -H unix://
Environment=PATH=/usr/libexec/docker:/usr/bin:/usr/sbin
ExecStart=/usr/bin/dockerd-current
–add-runtime docker-runc=/usr/libexec/docker/docker-runc-current
–default-runtime=docker-runc
–exec-opt native.cgroupdriver=systemd
–userland-proxy-path=/usr/libexec/docker/docker-proxy-current
–init-path=/usr/libexec/docker/docker-init-current
–seccomp-profile=/etc/docker/seccomp.json
$OPTIONS
$DOCKER_STORAGE_OPTIONS
$DOCKER_NETWORK_OPTIONS
$ADD_REGISTRY
$BLOCK_REGISTRY
$INSECURE_REGISTRY
$REGISTRIES
ExecReload=/bin/kill -s HUP $MAINPID
LimitNOFILE=1048576
LimitNPROC=1048576
LimitCORE=infinity
TimeoutStartSec=0
Restart=on-abnormal
