I have installed the latest version of ShinyProxy, Docker for Mac, and the shinyproxy demo docker image. I am getting this error when I try to run a shiny dashboard.
Error
Status code: 500
Message: Failed to create container
I suspect that the problem is that ShinyProxy is not connecting to the docker host. I have read the documentation located at https://www.shinyproxy.io/getting-started/#docker-startup-options. However, these instructions are for Linux, not macOS. I have spent a couple hours searching, and have not had luck finding instructions on how to set DOCKER_OPTS on macOS. Does anyone have instructions on how to do this?
-JW
