Get proxyId within R
#1
I noticed that the latest version introduce a more user-friendly URL. That’s great, but is it possible to add the proxyId in the environment variable, accessible from R? In previous versions, I split the URL, but I can’t anymore with the new version.
Best
#2
It is not possible to modify the environment once the container starts.
Do you have a suggestion to get the proxyId within R? Or a workaround to be able to control the container from within R?
#3
Hi @KZARCA,
Yes, using expressions, you can insert the proxy id as an environment variable, e.g.:
  - id: 01_hello
    container-env:
      PROXY_ID: "#{proxy.id}"
#4
That’s great !
Thank you
