grafana resources dashboards not showing any data
We have deployed the shinyproxy operator in a single host with docker backend as documented in Docker | ShinyProxy and we enabled monitoring as documented in Docker | ShinyProxy
We are using docker images openanalytics/shinyproxy-operator:2.3.1 and openanalytics/shinyproxy:3.2.3 and many of the grafana dashboard work fine but dashboards “ShinyProxy App Resources” and “ShinyProxy Delegate App Resources” don’t show any data. All the dashboards show some data if I select a big enough time frame in the top right corner (e.g. 7 days) except these two.
Do you have any advice about how to get these two dashboards working?
Thanks!
I debugged this issue with the help of an LLM and the problem seems to be that the current setup of the shinyproxy operator only works with the docker overlay2 driver but new docker installations use overlayfs driver. See the notes in OverlayFS storage driver | Docker Docs and Storage drivers | Docker Docs
I have switched to overlay2 driver by now so workaround the issue and now the grafana dashboards for shinyapps resources work fine.
I thought I would post here the details so the shinyproxy developers are aware of the issue. I paste below more details provided by the LLM
Storage Driver: overlayfs is not the classic Docker overlay2 driver. It’s the marker for the containerd image store (the “containerd snapshotter” feature) that Docker 25+ ships and that is enabled by default in Docker 28’s fresh installs. Confirmation: /var/lib/docker/image/contains only identity-cache.db — no overlay2/ or overlayfs/ subdirectory with a layerdb/. Under the containerd snapshotter, image and layer metadata live under /var/lib/docker/containerd/… (containerd’s content store), not the classic image//layerdb/mounts//mount-idlayout that cAdvisor was written against.
cAdvisor doesn’t support the containerd snapshotter when talking to Docker — it unconditionally goes looking for image//layerdb/mounts//mount-id, that file doesn’t exist, container init fails, and every per-container metric gets dropped. Tracking issues:google/cadvisor#3624 and friends. It’s a Docker‑side feature change, not a cAdvisor version regression.
Two real options
Option A (recommended): disable the containerd snapshotter
This reverts Docker to the classic overlay2 graph driver layout that cAdvisor understands. Edit /etc/docker/daemon.json and either remove the feature flag or set it to false:
{“features”: { “containerd-snapshotter”: false }}
Then:
sudo systemctl restart docker
Important caveat: switching image stores invalidates the current store — you’ll see your image list become empty. Pull the images you need again (docker pull openanalytics/shinyproxy:3.2.3, etc.). Running container instances of those images may keep working until you restartthem, but plan a maintenance window: re-pull, restart ShinyProxy and any apps, and you’re back. After the restart, docker info | grep “Storage Driver” should read overlay2, and /var/lib/docker/image/overlay2/layerdb/ will exist. The cAdvisor errors will stop and the twodashboards will populate within one scrape interval.
Option B: keep the containerd snapshotter, replace cAdvisor’s data source
cAdvisor can monitor containerd directly via --containerd=/run/containerd/containerd.sock --containerd-namespace=moby (Docker uses the moby namespace) instead of Docker. That avoids the broken layerdb lookup. But the operator hardcodes the cAdvisor flags in CAdvisorConfig.kt:91,so you’d need a wrapper image:
FROM gcr.io/cadvisor/cadvisor:v0.49.1ENTRYPOINT [“/usr/bin/cadvisor”, “–containerd=/run/containerd/containerd.sock”, “–containerd-namespace=moby”]
…also bind‑mount /run/containerd into the cAdvisor container — which the operator doesn’t do, so you’d additionally have to either patch the operator or run cAdvisor outside the operator (SPO_ENABLE_MONITORING=false and bring your own shinyproxy-monitoring stack). This is morework and the container-label translation under the containerd path is less battle-tested than the Docker path.
My recommendation
Go with A. One config change, one daemon restart, one round of docker pull, and you’re using the same setup the operator’s monitoring was designed and tested against. The containerd snapshotter is forward-looking but the surrounding tooling (cAdvisor in particular) hasn’t caughtup.
Thanks for opening this issue, I did some investigating and come to a different solution than the LLM. cAdvisor does not look at the storage of docker directly. However, I was able to reproduce the issue that the app resources dashboard is not working.
The good news is that this can be fixed by updating cAdvisor. You can do this by specifying a custom image in your docker-compose.yml file:
services:
    image: openanalytics/shinyproxy-operator:2.3.1
    environment:
      SPO_ORCHESTRATOR: docker
      SPO_DOCKER_GID: 988
      SPO_CADDY_ENABLE_TLS: "true"
      SPO_ENABLE_MONITORING: "true"
      SPO_CADVISOR_IMAGE: "gcr.io/cadvisor/cadvisor:v0.57.0" # add this line
EDIT: I just verified that the instance on which I was testing this is using the overlayfs driver:
vagrant@vagrant:~$ sudo docker info 2>/dev/null | grep -E "Storage Driver|Docker Root Dir"
 Docker Root Dir: /var/lib/docker
