Hi all,
I’ve been adapting Shinyproxy/Containerproxy to run on an istio-enabled kubernetes cluster. I can launch & delete the app containers using the Shinyproxy UI with mTLS enabled, and can receive a correct html reponse with curl from the shinyproxy container, but I’ve hit a wall - 400 bad request when trying to access the app via /app or /app_direct.
With very little Java experience I’m looking for help tracing the source of the error below. The incorrectly formatted target is in bold in the debug log snippet below (taken during initial launch of the app via the shinyproxy ui). It should read:
sp-service-3057736c-68b8-49e6-994b-02386c6b8eed.mynamespace.svc.cluster.local:3838
but instead reads:
sp-service-3057736c-68b8-49e6-994b-02386c6b8eed.mynamespace.svc.cluster.local/11.65.233.111:3838
The key-value proxy mappings appear to be correct, so the unwanted “/” & internal IP (faked here) is being added somewhere else during attempted access.
I’d really value some suggestions of where to look. I’ve spent a lot of time chasing this down, and seem to be going round in circles. My plan is obviously to submit a pull request to containerproxy once I’ve cracked this to allow it to be used on an istio-enabled setup.
Many thanks,
Stuart
2019-11-10 17:47:56.386 DEBUG 1 — [ XNIO-2 task-1] o.s.c.e.PropertySourcesPropertyResolver : Found key ‘proxy.admin-groups’ in PropertySource ‘configurationProperties’ with value of type String
2019-11-10 17:47:56.387 DEBUG 1 — [ XNIO-2 task-1] o.s.c.e.PropertySourcesPropertyResolver : Could not find key ‘proxy.admin-groups[0]’ in any property source
2019-11-10 17:47:56.395 DEBUG 1 — [ XNIO-2 task-1] io.undertow.request : Matched prefix path /proxy_endpoint/85194935-1137-426e-b7f3-81cdc954f445 for path /proxy_endpoint/85194935-1137-426e-b7f3-81cdc954f445/
2019-11-10 17:47:56.397 DEBUG 1 — [ XNIO-2 task-1] o.s.web.servlet.DispatcherServlet : Null ModelAndView returned to DispatcherServlet with name ‘dispatcherServlet’: assuming HandlerAdapter completed request handling
2019-11-10 17:47:56.397 DEBUG 1 — [ XNIO-2 task-1] o.s.web.servlet.DispatcherServlet : Successfully completed request
2019-11-10 17:47:56.397 DEBUG 1 — [ XNIO-2 task-1] o.s.s.w.a.ExceptionTranslationFilter : Chain processed normally
2019-11-10 17:47:56.398 DEBUG 1 — [ XNIO-2 task-1] s.s.w.c.SecurityContextPersistenceFilter : SecurityContextHolder now cleared, as request processing completed
2019-11-10 17:47:56.398 DEBUG 1 — [ XNIO-2 task-1] o.s.b.w.s.f.OrderedRequestContextFilter : Cleared thread-bound request context: HttpServletRequestImpl [ GET /proxy_endpoint/85194935-1137-426e-b7f3-81cdc954f445/ ]
2019-11-10 17:47:56.426 DEBUG 1 — [ XNIO-2 I/O-1] io.undertow.server.handlers.proxy : Sending request ClientRequest{path=’/’, method=GET, protocol=HTTP/1.1} to target sp-service-3057736c-68b8-49e6-994b-02386c6b8eed.mynamespace.svc.cluster.local/11.65.233.111:3838 for exchange HttpServerExchange{ GET /proxy_endpoint/85194935-1137-426e-b7f3-81cdc954f445/ etc
