I am trying to run my own Shiny app through ShinyProxy. I have a file in my application folder called BaseEnvironment.RData which is an environment file containing my data. I assume I am supposed to load this during initialization through my DockerFile. I have this in my DockerFile
load('BaseEnvironment.RData')
but I am getting the following:
Error in readChar(con, 5L, useBytes = TRUE) : cannot open the connection
Calls: load -> readChar
In addition: Warning message:
In readChar(con, 5L, useBytes = TRUE) :
cannot open compressed file ‘BaseEnvironment.RData’, probable reason 'No such file or directory’
Execution halted
It seems I don’t know how to properly reference data dependencies/files. In the template apps, the data seems to be packaged up in the libraries. How should this be handled in my case, where the data should be coming from files on my server?
I can run setwd on certain folders, but not others. It also doesn’t seem like a permissions issue because I have done chmod 777 and still no avail… How do I load an environment file at the start of loading the app/container??
