SOLVED. SEE BELOW.
ORIGINAL QUESTION:
First, thanks for this awesome tool.
I am trying to use the custom templates found on the ShinyProxy GitHub page. (I’m limited to two links.)
Everything works fine (application launches, etc.) except for the the new landing page layout/theme; I still see the default bullet layout.
Here is my application.yml
title: Company Analytics
template-path: ./templates/1col
port: 807
container-wait-time: 100000
authentication: none
url: http://host.docker.internal:2375
- id: shiny_planting_schedule
display-name: Planting Schedule
description: Linear programming to optimize planting schedule.
container-cmd: ["R", "-e", "source('/root/shiny_planting_schedule/source_file.R')"]
container-image: shiny_planting_schedule
container-network: sp-example-net
And I’m using the same Dockerfile
provided in 02-containerized-docker-engine:
FROM openjdk:8-jre
RUN mkdir -p /opt/shinyproxy/
RUN wget https://www.shinyproxy.io/downloads/shinyproxy-2.2.1.jar -O /opt/shinyproxy/shinyproxy.jar
WORKDIR /opt/shinyproxy/
CMD ["java", "-jar", "/opt/shinyproxy/shinyproxy.jar"]
To run the Dockerfile
I do the following in PowerShell:
cd C:\Users\user\Documents\R\shinyproxy\test
docker network create sp-example-net
docker build . -t test
docker run -d --name test --net sp-example-net -p 807:807 test
The templates/1col
folder is in the same folder as the Dockerfile
and the application.yml
I tried following the tutorial outlined in 04-custom-html-template but then I get a container failed to start error.
SOLUTION:
The answer is embarrassingly simple. The Dockerfile
needs to be edited so that the templates
folder is copied into the image.
The edited Dockerfile
FROM openjdk:8-jre
RUN mkdir /opt/shinyproxy/templates
ADD templates /opt/shinyproxy/templates
Thanks again to the ShinyProxy developers for an amazing platform!
